Hello all
I have started using Sweethome software and day by day learning new things and getting impressed with the output.
One of the reason i started looking for a sweet home kind of software is the image in the below link
http://www.palash2i.com/floorplans.html
I was very impressed with the clarity of this image
Can we do a similar image with our sweet home software OR is there any other sophisticated software to get this good an image?
Regards
Sudha
Can we make a similar floor plan with our Sweet Home software?
This topic has been viewed 6815 times and has 6 replies
sudhaathreya
Re: Can we make a similar floor plan with our Sweet Home software?
Sudha,
There's no reason why you couldn't make something very similar with SH3D.
It only takes:
- the time to really learn the program
- the right models for your furniture
- the right textures for your surfaces.
You would then have to try out how to render the photo, playing a bit with the illumination.
It only takes:
its quit easy to make the image like that just decrease the height of the walls or just make them transparent place all the furnitures
adjust some lights create advanced rendering photos there the image is nicer then the one you have seen.....
sudhaathreya
Thanks for the reply
I will try and hopefully with experience, i can make better pictures.
Couple of challenges that i have are:
1.Print is very small and the entire floor plan is not clearly visible and
2. When i zoom the smaller picture, the quality goes down
Any suggestions please?
Regards
Sudha
Regards
Sudha
change the size of you picture while you create the pictures by increasing the pixals i.e height and width.
http://www.mediafire.com/?o580tfoaghpvn3d
Here are some pictures i did just in short time use nice furnitures and place lights properly to get amazing snaps
this image is created using advanced rendering plugin!
http://www.mediafire.com/imageview.php? ... 15&thumb=5
http://www.mediafire.com/i/?dodsowfk5ppyfn0
sudhaathreya
Thanks for your reply
I am not seeing Create Advanced photo option..am i missing something?
Regards
Sudha
Regards
Sudha
Sudha,
If you use version 2.6, you can install the AdvancedRender plug-in. See the tutorial.
If you use version 3.0, the functions of that plug-in have been integrated into SH3D, so you don't need the plug-in. However, would you prefer the plug-in, it still can be installed, and is working correctly.
