bug in time setting?
This topic has been viewed 23869 times and has 5 replies
Emmanuel,
Maybe there is a small bug in the time setting of the rendering dialogue. When I click up and down, the time changes in steps of 1 hour. When I try to set a specific time, say 08:45 AM, things become difficult.
When I delete the entire time and start typing 08:4, the cursor jumps forward and I get something like 08:4A5M. Probably it's a bug that's there before v3.0, but as I rarely use other setting than 12:00 I've never noticed it before.
Re: bug in time setting?
The best thing would be to replace the date and time fields by something a little more... easy to handle like a calendar and a clock.
Emmanuel,
Maybe this is a stupid answer....
Emmanuel,
Exactly the same bug as described in the first post of this thread is happening in the Edit Furniture window. I'm not quite sure yet if I can reproduce it on command, but I think I can give a hint.
It happens when you enter a value like .123, and it doesn't happen when you enter 0.123. Also, The model section W-D-H seems to be affected only. The X-Y-elevation part doesn't show this problem.
I'll keep an eye open to see what-when-where.
minaaaa
Post by minaaaa »
i got exactly the same one
With the current version (7.5) I see no problem with this.
When you enter the time field the up/down keys change the hour. A single right arrow key switches to the minutes and you can change these with up/down. If you have a time with AM/PM then another arrow right switches to the AM/PM part and you can change it with up/down.
