cool High priority Television Feat.Wolverine
This topic has been viewed 23750 times and has 2 replies
wrosun
Country: Pokhara, Nepal
Post by wrosun »
Hello Friends!
Here is a lcd televison that
reflects Lights and is transparent so it displays a picture of wolverine
. Hence it is Named "Televison Feat. Wolverine".
It must be place inside a room that has ceiling i.e create room and check on display ceiling. Then place a light source or just check on ceiling light to give your room a light source it works outside a room also but you need to make the sunlight rays hit on the screen of yout tv to make the image visible. To make lighting efect from the TV you can also use advanced rendering lights and check on lamp lights whilw rendering. Keep the quality on best all the timr for better results. check on compute glass transparency just to be sure.
You can download it from here
tv:only ceiling light turned on
Tv:ceiling + three more lights turned on
use more lights to make the screen more bright!!
[Note from moderator: fixed image links]
wrosun
Re: Television Feat.Wolverine
Post by wrosun »
Thanks Puybaret
for fixing the image links.....
What do you think about the TV?
wrosun
Post by wrosun »
Guys i found out one thing that causes the tv to not be transparent.....if you have checked in sunlight while rendering then the tv wont look like its turned on...even if its placed inside a room also...
