Is it possible to lock the objects Height- Width, so that the user can not change it ?!
How ?
Regards,
Alireza Fattahi
Lock Object Height, Width
This topic has been viewed 3569 times and has 2 replies
Re: Lock Object Height, Width
i put a similar wish to the wishlist.
- Lock Base Plan (Flag for every Object)
So you could lock every object you want. On the top left you have a flag to lock but right now you lock walls and rooms only... i would like to choose which objects should be locked with this check.
Alireza, in case you didn't guess it from Hampi's wish list, you can't lock the height and width of 3D objects in the current version.
