big grin new plugin ready to use - duplicate style plugin
This topic has been viewed 59864 times and has 11 replies
white0demon
Post by white0demon »
I have created the duplicate style plug-in
https://sourceforge.net/tracker/?func=d ... id=1127349
If you have any suggestions or if there are any bugs please let me know
fhoofman
Re: new plugin ready to use - duplicate style plugin
Post by fhoofman »
what does it do?
and how to activate it?
white0demon
This is how to use it:
http://www.sweethome3d.com/userGuide.jsp
It's right in the end of the page.
As the description says in the link in my previous post, it copies the colour or texture you have set to an item to other items you have selected. For example it can copy the texture of the sink to the bathtub and the toilet.
Let me know if it doesn't cover your questions [:)]
fhoofman
Post by fhoofman »
ow, I see. what if I want to use the original colour / texture and then apply to the new item?
white0demon
What do you mean?
If I understand correctly you double click to the item and select the radio button "Default colors and textures" and then do the duplicate style process.
As it modifies the selection, your plug-in should handle undo/redo too with the UndoableEditSupport object returned by getUndoableEditSupport. Look at other plug-ins or at PlanController class for many examples.
white0demon
I added version 3 with undo and redo included :)
maker
Post by maker »
Works very well, thanks. I wonder if it could be extended to "reverse" right and left face colours.
That way it can be used as a fast way to give all "inner" walls of a room one colour. Or for giving a brick texture to all outer walls of a house -- and the inside coloured.
Thanks.
maker, isn't the Plan > Reverse walls direction menu item enough?
maker
Post by maker »
Not for me [:D] (on Win XP Pro)
Does it work that way in Linux/Mac?
