smile AdancedRenderingMini-1.6.sh3p
This topic has been viewed 56011 times and has 16 replies
db4tech
Country: UK
Post by db4tech »
Hi all,
Something I was discussing with Emmanuel sparked an idea!
My display resolution is quite low, so it is easy to run out of space.
With that I mind I had the idea of producing a mini interface version of the AdvancedRendering-1.6.sh3p plugin, for people with lower resolutions displays, the size is designed especially so Netbook users can also enjoy the new plugin.
AdancedRenderingMini-1.6.sh3p [:)]
This image shows a size comparison.
The mini interface is using the same font size, which is more user friendly as it helps people who may have vision problems. To keep the interface as small as possible, I abbreviated some of the option labels.
Everything still works the same, but I will wait for Emmanuel's approval before offering it as a download.
Do hope this will be helpful for users!
db4tech
Edit:
31-08-10 Added the download. (Directly below this text)
Looks a bit lost within the long description I added, Oops!
AdvancedRenderingMini-1.6.sh3p
(103.79 KiB) Downloaded 1126 times
Re: AdancedRenderingMini-1.6.sh3p
No problem db4tech, go forward! [;)]
db4tech
Country: UK
Post by db4tech »
Merci Emmanuel, also for your help with the French translations. [:)]
Would you like me to add it here, or will you be hosting it on the Sweet Home blog page with the full size Advancedrendering-1.6.sh3p plugin so it is easier for users to find?
I've been thinking, since you have a furniture page, what are your thoughts on adding a plugin page, there are some great plug-ins talked about in the forums, but they can be difficult to find once a post becomes old.
I guess they will most likely be in the 'List Attachments' section, although if they had their own page, a nice description and maybe a small image of the interface would be helpful?
Interested to hear your thoughts.
Thank you! [:)]
db4tech
db4tech, Emmanuel.
The plug-in page is a great idea!
I'll have to think about this plug-in page...
whippetsleek
Post by whippetsleek »
Just my 2cents, and you can tell me to keep my nose short, but since you have a developer and plug-in forum, you could make a thread with all the plug-ins, and sticky it to the top so that it is always visible. That way no extra page to make.
db4tech
Country: UK
Post by db4tech »
Download added! (End of first post) [:)]
Please let me know if there are any problems.
Enjoy! [:)]
db4tech
fhoofman
Post by fhoofman »
please view my small trial render, and you'll see a white spots around the imageImage
is that normal or there's something wrong with the plugin
fhoofman
Post by fhoofman »
fyi, I choose option rendering silk and then white spot happen.
when I choose gloosy, it's just normal, nothing errorImage
Hampi
Post by Hampi »
thank you, this match perfekt on my sub-notebook
