To fulfill a picture as texture in object
This topic has been viewed 3694 times and has 2 replies
I imported an object (a frame)and I inserted a picture using texture. My problem now is that the picture inserted is showed as multiple pictures of the same. I'm not able to fullfill the space with one image despite change diferent mesurements. Any help?
Re: To fulfill a picture as texture in object
Try this:
Double-click the frame.
Open Texture, then on the left side, choose your texture (again!). Click Modify->Continue. Make sure that the Width and Height match he actual dimensions of your frame. Click on Finish.
If the proportions of your Frame do no match the proportions of the image, you can change it. Or modify the image in an image editor to match.
Hope this helps
Hope this helps
Thanks.
I tried importing already framed picture and change JPG in it. It works.
