How to make a roof light and a corner sink?
This topic has been viewed 6111 times and has 4 replies
Dirki
Post by Dirki »
How can I make / use a horizontal roof light and a corner sink (from corner to both sides 90 cm)?
Actual (none Beta) stable, portable Sweet Home 3D
Windows 7 Premium Home Edition & Vista
Re: How to make a roof light and a corner sink?
Lights can be only point lights until now.
You'll have to build the corner sink from a basic sink that you'll surround with triangle and boxes, or probably better with an other program like AOI or Blender.
Dirki
Post by Dirki »
Thank you Emmanuel,
Okay, doesn't seem to be that easy...
Thanks again, nice greetings, Dirk
maker
Post by maker »
Alternative suggestions:
1.You can add multiple lights in an array to simulate the roof-light.
2.You can use poseray ( http://mysite.verizon.net/sfg0000/ ), import OBJ files.Then convert your light to "array" and use povray renderer (povray.org) to render.
3. Import OBJ in Kerkythea (www.kerkythea.net), replace lights/materials as needed, render.
Hope this helps (at least a little bit ;) )
Dirki
Post by Dirki »
Many thanks maker,
Yes, of course, it helps. I will try...
Many thanks again, above all for the links. Nice greetings, Dirk
