How to resize imported furniture while keeping aspect ratio?
This topic has been viewed 7041 times and has 3 replies
hftinga
Country: Amsterdam, Nederland
Post by hftinga »
I imported a piece of furniture which was created in Sketchup successfully.
But how do I resize it while keeping aspect ratio?
When I hover the mouse pointer at the bottom left I can see the resize icon which also works fine, but I want to resize the furniture while keeping its original proportions.
Is this possible in Sweethome3D?
Thanks,
Helma.
db4tech
Country: UK
Re: How to resize imported furniture while keeping aspect ratio?
Post by db4tech »
Hi Helma,
Welcome to the Sweet Home forum. [:)]
The easiest way (if you already know the dimensions required) is to enter either a height, depth or width while importing the furniture, entering any value in this section will change all other values proportionally.
Enter either a height, depth or width
Once the furniture or model is already imported, use the Modify furniture editor but you will need to work out what values to enter in each box, to keep the correct object proportions. (I have requested a Constrain Proportions tick box for the modify furniture window but until then use the methods above)
Modify furniture window
Or
Just thought of another idea!
Another way is to use the new Furniture Library Editor version 1.0 tool (no install needed, just double click to run) import your model, set the size you want, then save and import into Sweet Home.
db4tech
Helma, db4tech:
There is a 4th way to modify your model after importing that works on models that have been imported separately using the function Furniture --> Import furniture. You can recognize these models because in the model list (top-left window) their name is in italics.
Choose the model to modify, right-click it and a window opens that offers 5 options: Copy, Delete, Add to home, Modify furniture and Import furniture. Choose Modify furniture and proceed as in the first method db4tech described.
hftinga
Post by hftinga »
Thanks for your help.
Helma
