Renders of more than 3,000 pixels, also Selection area
This topic has been viewed 4071 times and has 0 replies
db4tech
Country: UK
Post by db4tech »
Hi Emmanuel,
Please can you allow renders of more than 3,000 pixels wide. Say raising the maximum to 10,000 (for producing very large prints) 3,000 can be up-scaled but then it softens details. I understand that higher resolutions require more rendering time but I don't mind leaving it rendering overnight.
Also while on the subject is it be possible to allow a rectangular selection area within the render window to be defined? The default is to render the whole scene unless a selection is made.
Picture the scene (it has happened to me more than once [:)] ) a large resolution render just completes and then you realise that something small is wrong and need a slight alteration, instead of having to re-render the whole scene just the area required can be selected, then the two images can be blended in image manipulation software.
Mock-up
Hope you are having a good week and not working too hard on version 2.5, you can work hard on the Uber render but not Sweet Home [:D] (Kidding!)
db4tech
