Slat wall panels for TV media walls – free SH3F furniture library (8 models)
This topic has been viewed 13 times and has 0 replies
getmediawall
Post by getmediawall »
Hi all,
Slat acoustic panels (wood slats on black felt) are everywhere in living rooms now, usually behind the TV, and I could not find them in the default catalog, so I made a small free library.
What is inside
  • 8 models: 4 finishes (White Oak, Walnut, Black, Gray) x 2 heights (8 ft / 244 cm and 9 ft / 274 cm)
  • Each panel is 61 cm (2 ft) wide and 2.4 cm deep: 15 slats on a felt backing, the size these panels are usually sold in
  • They appear in a new Media wall category after import
GetMediaWall-Slat-Panels.sh3f (15 KB) – double-click it or use Furniture > Import furniture library...
The same models as OBJ + MTL for other programs and the small Python script that generates them (change width, height, slat count or colors and rebuild) are here: https://github.com/getmediawall/sweethome3d-slat-panels
Tip: put the panels side by side with no gap and divide the wall width by 61 cm (round up) to know how many you need – a 3.66 m (12 ft) wall takes 6. If you want to try finishes, a TV size and a fireplace on a wall before modelling the whole room, I also made a free browser planner that draws the wall to scale and counts panels: GetMediaWall Design Your Wall.
Models are CC BY 4.0, so feel free to use them in your projects. Feedback and requests (other widths, LED strips, different slat spacing) welcome.
Dmytro
