Application size
This topic has been viewed 4470 times and has 1 replies
jfdecw
Country: England
Application size
Post by jfdecw »
installed "Sweet Home 3D" on laptop with Fedora 44.
Resolution 1920 x 1080
Refresh rate 120.07 Hz
Menu font is VERY small, ie microscopic!
Zoom in works for design pane, but does not change top menu nor furniture sections down the lhs.
Any thoughts?
Jon
Re: Application size
What version of Sweet Home 3D?
Did you install from the repository or did you download the latest version (7.5) from sourceforge.
If you installed the repository version then replace that with the 7.5 version. If the problem persists check the java version. The sourceforge download comes with its own java runtime but some newer java versions work well too, others can cause problems.
Don't install any flatpak downloads. They tend to "optimize" installs by removing what they think is a double install, like the java runtime distributed with Sweet Home 3D.
If that doesn't solve it search for "Texts in the furniture catalog are not displayed correctly" in the FAQ .
