smile Sweet Home 3D 2.4
This topic has been viewed 328641 times and has 36 replies
Sweet Home 3D 2.4
The first Beta of Sweet Home 3D 2.4 is available as a Java Web Start application.
At this time, its main new feature is the support for DAE/Collada file format: this means you have now access to Google 3D Warehouse and its huge library of 3D models!
For example, the following image contains only furniture and characters imported from Google 3D Warehouse:
This Beta version fixes also a few other things, among which:
- objets exported at OBJ format then reimported in Sweet Home 3D have now the same look (see this thread),
- the support for transparent textures was added,
- the bug that prevented overlapping floors to be correctly displayed is fixed.
Expect more features in the next Beta updates. [:D]
Developer comment: Sweet Home 3D 2.4 was released on 05/25/2010.
db4tech
Country: UK
Re: Sweet Home 3D 2.4
Post by db4tech »
Wow thanks! [:)]
One question is this a small bug or should it now be showing a full description path for the virtual vistor?
Also and this is something really small, the program icon is corrupt on Windows 7. It is fine with version 2.3.
Here is a 200% enlargement to help show the problem (the blue background was from my current desktop background and is not part of the icon)
db4tech
Emmanuel:
Both are the same on Ubuntu 10.04.
It's a bug and I fixed it.
I noticed also that transparent textures don't work at this time at highest rendering quality level. I'll have to check if SunFlow can support that.
By the way, the DirectX version of Sweet Home 3D 2.4 Beta is also available.
Thank you for mentioning it.
If you run Sweet Home 3D 2.3 from its installer version, I guess this is a bug in Java Web Start.
db4tech
Country: UK
Post by db4tech »
Thank you for the fixes.
I'm not a programmer but was the virtual visitor long description showing because a semicolon had been missed, separating the code description from the code?
One thing that may put people off testing the new version, this warning always shows (unless the 'Always trust...' box is ticked) with both the web start version and the DirectX version on Windows 7.
What are yours and others thoughts on moving a couple of things?
The Preferences from the File menu to the Edit menu. (Since changing preferences is editing something, plus most other programs have preferences found on the edit menu. Will help new users if preferences are where they are used to finding it, regular users will soon adapt to the change)
Also
Moving the Export to OBJ format... from the 3D view menu to the File menu since clicking on Export to OBJ format... always saves the full model and not just what is visible in the 3D view.
I was going to make these suggestions with version 2.3 but then thought you were busy with other things, so now is the perfect time when coding a new version.
db4tech
Edit: To fix a couple of typos.
db4tech
Country: UK
Post by db4tech »
Also while you are coding your new version. Do you know about the growing Furniture catalog view: bug, causing all other windows to shrink? it happens with both versions 2.3 and 2.4, seems to happens for both Category folder and Searchable list options.
It only seems to happen when in full screen mode (maybe it's because I'm using a wide-screen display?)
If it's helpful I have made a tiny low resolution 18 seconds video to let you see what happens to the display each time a file is saved then opened again.
Sorry about giving you more work while you are busy working on advanced Uber shaders [:D] (just kidding!)
db4tech
Growing windows bug video.wmv
(173.36 KiB) Downloaded 8550 times
Gentlemen:
I cannot reproduce this bug on my PC (Ubuntu 10.04, screen 1680x1050, SH3D v2.4b2) or on my laptop (Windows Vista, screen ?, SH3D v2.3)
It's just a misplaced end of line delimiter in the resource file that gives the menu names displayed in English.
This security dialog is displayed for any Java Web Start version of Sweet Home 3D and for the online version too.
In a way, it's not normal that the installer versions under Windows and Linux don't display such a dialog, because the user should always be warned about the risks of launching a program able to write on the disk, run DLLs...
The only improvement I can do in this dialog is about the "cannot be verified" text: if I buy a Java Code Signing Certificate, it will say "has been verified", but this certificate costs at least 200 $/year! Not sure it's worth it for a free program... [:(]
My stupid answer would be "use Mac OS X"! [;)]
Under Mac OS X, they solved this problem by proposing the Preferences item in the application menu displayed for each program. Here's the French application menu for Sweet Home 3D:
On other systems, I miserably didn't see any common rule; Preferences are sometimes in a Tool menu, sometimes in the File menu, sometimes in the Edit menu or elsewhere, and often it's named Options and not Preferences!
So sorry I won't move it.
This remark is applicable to the Export to SVG format... menu item too, and any Export to ... format that will appear in the future. [:(]
Even if these menu items handle files, I chose to put these items in the Plan and 3D view menus to suggest to beginners what kind of information would be exported.
I'm not aware of this problem.
Do you mean that the Furniture catalog view grows without doing anything like in the video??? When does it stop growing?
db4tech
Country: UK
Post by db4tech »
Hi Emmanuel and Hans,
Each frame (or window position change) in the video shows what happens when a Sweet Home file is saved, the Sweet Home program is closed, next the file is opened again, file is saved (without making a changes) close the program, open the file and save the file again and so on.
Each frame of the video shows one screen capture when the Sweet Home file is opened.
Under normal use the windows only change (jump) once and I drag them back to the original positions before doing any work on the Sweet Home building before saving.
The video was created to see just how far the windows would keep moving if the user didn't keep dragging them back.
Hope this makes sense.
Emmanuel, to answer your question, the end of the video shows the maximum distance the windows seem to travel.
To help isolate what might be causing this (in case it was a hardware driver problem or operating system issue) I have just tested it for you using XP Pro under visualization (completely different OS and drivers for virtual hardware) and also a slightly older version of java and it does exactly the same thing, in windowed mode everything stays the same but once the program is full screen the widows change/jump positions (only) once, as soon as a file is opened.
I'm using a 16x9 aspect ratio display if it's helpful.
PS: I don't think I will be buying a Mac just so the preferences show in a different place. [;)]
db4tech
db4tech
Country: UK
Post by db4tech »
Ah but Export to SVG format... makes sense under the Plan menu option as it is just the plan view that is converted to SVG.
The Export to OBJ format... differs as the whole model (not just what is visible in the 3D view is converted to an obj file) since it is located under the 3D view menu I thought new users might think only what they see in the 3D view is converted to an obj.
db4tech
