When I open the Plugin Manager in SH3D 7.5 I get the error ¨Failed to download the plugin list: Connection reset¨.
The URL in Settings is https://daniels118.altervista.org/sh3d/ ... lugins.xml.
Question is there another URL or what is causing this. Unable to reach daniels website from China. That might be the problem!
Plugin Manager Repository URL
This topic has been viewed 79018 times and has 1 replies
Re: Plugin Manager Repository URL
If you can't reach daniels website then the plugin can't retrieve the latest plugins.xml file. Perhaps Daniel can add the plugins.xml file on sourceforge with each update so that the Plugin Manager can retrieve it from there. That is, if you can can reach sourceforge, otherwise the result will remain the same. Daniel will know if retrieval from sourceforge is an option.
