hello!
I have been modelling my home in 3d to visualise seom rennovations I am doing.
I have gotten some amazing results from the photo utility and am very happy with eth render quality and the software in general. Great job to all you developers!
I do have one question....
When I use sloping walls to get a sloping ceiling (i.e. a vaulted or cathedral ceiling etc) the light source in the centre of each room ceililng that usually 'turns on' in the rendered picture doesnt turn on. As a result, the room is not lit in the rendered drawing.
I am using multiple 'rooms' to get multiple light sources within the room, inlcuding the sloping ceilings.
Any thoughts or help would be appreciated! I will load some pics to the gallery once I work out how to do it!
Regards
sloping ceilings and light sources
This topic has been viewed 12831 times and has 5 replies
Re: sloping ceilings and light sources
I know the way the location of lights on sloping ceiling is computed isn't perfect and I should improve it.
I suggest you to split your room in two joined rooms: one that will match the sloping ceiling and the other one matching the rest. The light at the ceiling of the second room should be ok in that case, if its middle is under the ceiling.
You may also give a try to the advanced rendering plug-in that lets you place lights where you want.
- vaughan
- Country: Cairns, Queensland, Australia
- Contact:
Thanks for the info, I will try to do what you have suggested.
I have the latest rendering update - quite impressive. I like the facility to switch lighting modes.
Do you have a link to a suitable 3ds object that I could import that would function as a recessed ceiling light? Some of the lighting objects in the various libraries do not actually provide lighting.
Regards
Regards
Vaughan:
Here is a post that contains a link to a file with a general purpose light that you can use. However... it has several drawbacks.
Advantages:
- the lamp itself is invisible, only the light shows
Disadvantages:
- you cannot save it as an object
- you cannot place it inside a lamp
Advantages:
Disadvantages:
- vaughan
- Contact:
Thank you for the link
I have opened the file and copied over the light source into the building I am modelling.
I experimented with size, height and placement and I am able to have a lighting source on the inclined / sloping ceilings.
Thanks again for your help and also to Emmanuel.
I am very impressed with the Sweet Home package. I have used many CAD packages over the years (since Autocad release 10 in the 1980s - shows my age!) and I find Sweet Home to be quite intuative to use. The only other free pacakge that 'competes' would possibly be Envisioneer Express - but that product does not have the render cabability built in.
Overall, Sweet Home 3D is a fantastic modelling and visualisation tool. Keep up the development!
Finally, can I add or insert a picture into a forum post? I will add a pic of my efforts after the weekend. Unfortunately work gets in the way of my private life!
Here's a link to basicLights.sh3f, the furniture library file that contains the 3 individual lights mentioned in the blog article about the advanced rendering plug-in.
These lights are not recessed ceiling lights but I guess that it will render the same.
Vaughan, I added you to a group of users authorized to add files to their posts in the forum.
Thank you for your remarks. They are greatly appreciated. [:)]
