Moulding Boolean Convert plugin (MBC)
This topic has been viewed 187861 times and has 17 replies
dorin
Post by dorin »
Continuing the YAUP series, I tried to create this MBC plugin.
"Hell is paved with good intentions."
"Half of the answer lies in how you phrase the question."
"AI's depend on the NHS library."
"If you have one watch, you know what time it is. If you have more than one, you will never know."
It 's a plugin with three actions under the "Tools" menu:
-Add Moulding;
-Boolean Operation;
-Convert to furniture.
1. Moulding intends to replace and complete the Moulding plugin.
-You can now select multiple pieces of furniture and multiple rooms to mould.
-Moulds are now grouped by room and mould name.
-You have the option to generate matching corners, also grouped.
Some screenshots:
Add some moulding furnitures
Draw some rooms and select alls
The result
2. Boolean operations mean union, intersection, difference, and xor with selected pieces of furniture.
-Intend to be a new feature.
-It's just a start. Use it carefully!
-I've used the help of several AIs for this, and this is the most acceptable result out of about 50 versions.
3. Convert selected objects (furniture, walls, and/or rooms) into furniture.
-This is intended to make conversion easier than the Copy as New Furniture plugin.
-It is based on the Copy as New Furniture plugin, which, for unknown reasons, does not work for me.
-It is limited to furniture, walls, and rooms under the same conditions as the Copy as New Furniture plugin.
Some things works but many others don't.
Example:
-the horizontal and vertical coplanar faces are completely removed.
-operations with some simple objects (cube, sphere) don't work but work with moulding furniture library.
-with some complex furniture run OutOfMemory
Conclusion: There is a lot of work to do.
Here is this alpha1 version.
dorin
Re: Moulding Boolean Convert plugin (MBC)
Post by dorin »
The alpha2 version.
Having tried many different approaches, this is the closest to what I want.
What relatively works:
--Adding molding corners works acceptably.
--The Boolean operations work with many simple objects, except for spheres.
--Conversion into furniture works using a few common tricks.
Here are a few explanations as to why I tried to perform Boolean operations:
- to create unique objects myself
- to automatically make corners for borders and crowns.
Just a few samples:
1. I've want to make a hole for a sink on a countertop.
My first attempt was to subtract the sink from the countertop.
It works somehow, but not as I expected.
[pict1]Image
[pict2]Image
It seems that I need an auxiliary object to make the desired hole.
-Add a layer (not at the same elevation).
-Select, copy, and paste the sink onto the new layer. It will be used as a template.
-I increased the scale 10 times to make it easier to work with the walls and rooms.
[pict3]Image
-Draw some small connected walls and rounded corners at 90 degrees.
[pict4]Image
-Create a room inside the walls, select it and Tools->Convert to furniture
[pict5]Image
-Reduce the new object by /10
-Copy and paste the object back onto the first level.
-Make sure the new object and the countertop intersect.
-Select both and Tools->Boolean operation->Difference A-B.
[pict6]Image
[pict7]Image
-Acceptable.
2. I wanted to create some useless and difficult objects.
- Using the Basic shape generator plugin, I tried to extract different parallelepipeds.
[pict8]Image
and
[pict9]Image
- Now, from the result obtained, I want to extract an inclined and rotated cylinder.
[pict10]Image
and
[pict11]Image
Okay! Let's continue. From the last result, let's extract a sphere.
[pict12]Image
and
[pict13]Image
Failure!
Probably because it's the 13th picture or the plugin is useless.
Anyway, I know that if it works with spheres, it won't work with other shapes.
So use it with care!
Does the plugin use the obj definition for each object? (i.e. the definition in the .obj file.)
If so then try another sphere, one from my shapes library or one generated in Blender. Also try an Ico sphere from my shapes library, an ico sphere has a different kind of definition.
If that works then export the initial sphere you used and import it again. I suspect that it's definition is straight from Blender.
As it is, great results so far!
dorin
Post by dorin »
The updated alpha2 version.
The previous link is updated too.
I made a few changes and now it seems to be working.
pict14Image
pict15Image
pict16Image
pict17Image
pict18Image
@Keet Thanks, you've encouraged me!
The plugin (like SH3D) does not work directly with obj files.
-Exports the furniture as obj+mtl+texture to a temporary zip file;
-Loads it back as BranchGroup;
-Extracts the geometries from it and creates an Object3D (a kind of solid);
-Perform Boolean operations with two Object3D;
-Perform the steps in reverse order until the new furniture is added to home.
The XOR operations still don't work as expected.
Even so, use it with care!
I really like this plugin! With a little imagination and spatial insight you can create many model parts that would otherwise require the use of Blender.
Another step to create sophisticated models in Sweet Home 3D without the need of Blender. Thank you!
[hr]
A tip that might be helpful with some formulas and/or calculations:
If you have installed Blender, then look at the install directory. Many parts of Blender are Python scrips with formulas and calculations that can be converted to Java. Python scripts are plain text so easy to read and copy.
The latest version has some scripts integrated in the C source but of course you can also download the C source to find a specific formula. What I'm thinking about is smoothing, bending a cylinder, etc.
Found a bug with the difference calculation: When both objects have a height of 0 it generates an error: Boolean operation resulted in empty geometry
What was expected: the difference from the two flat surfaces.
When one of the two objects has a height >0 it works correctly, but of course I wanted a completely flat surface with a cutout.
Even with the error your plugin has already saved me several hours of work. Now I just have to remove all the faces below the top surface with Blender.
dorin
Post by dorin »
@Keet
0. Thanks again! As a non-programmer, it's an honor.
1. There are still many improvements to be made.
2. I have already installed Blender, but I also have AOI (ArtOfIllusion) .
3. Thank you for the advice! I have some knowledge of C++ (using QT) and Python as I know few things in Basic Spectrum.
4. Your suggestions are good, and I have been considering them for a long time.
4.1. Regarding smoothing, I believe there are some parameters in the obj file. I have seen that AOI imports such things.
4.2. Regarding bending a cylinder, I believe it is easier(for me) to create a bent cylinder directly by extruding (like under AOI).
4.2.1. I think I'll add "Extrude room" as other action of this plugin.
5.
<<I wanted a completely flat surface with a cutout.>>
This plugin works with volumes. First, it checks whether the two volumes overlap. 2*3*0=0
<<Now I just have to remove all the faces below the top surface with Blender.>>
I'm glad you found a workaround.
It is fool of bugs so, keep test it. Eventually test the others actions also.
dorin
Post by dorin »
@Keet
Your approach presented here is brilliant!
Basically, you need to make a negative of the hole you need.
Then you subtract it from the main object. Brilliant!
I've already done a few tests, it's not exactly simple but not impossible.
The result is acceptable.
This way, part of the smoothing can be solved (using a cylinder, torus, or some of the modeling library).
A tip: save and reopen the application from time to time. Will free the temporary memory.
This gave me the opportunity to discover a few more tricks.
Thank you!
What I presented is a practical example of what you can do with your new plugin, specifically the Difference option. Another basic use I can see is that it can replace or add to the window method of creating holes in objects. Once users find out how easy it is with this plugin it will soon become the favorite method for creating holes, especially since it is not limited to using a wall.
I think this plugin will become one of the most important plugins for users that create their own 3D models.
captaincook
Post by captaincook »
Bonjour Dorin.
Je suis resté perplexe au début en lisant tout ce que vous avez expliqué concernant votre nouveau plugin (MBC).
Mais après quelques essais, je crois que j'ai commencé à comprendre son fonctionnement et du coup les services qu'il peut rendre.
Bon, je crois que j'ai encore pas mal d'essais à réaliser pour bien le maitriser mais je pense que ça peut être très utile pour certaines créations.
Bravo à vous en tous cas et merci.
