please help me
This topic has been viewed 9988 times and has 10 replies
please help me
Hi every body ...
when I creat photo and choose best.. It takes long time then It does not apear
What is proplem ??
I have windowes system and version is 2.3
Thanks ,, [:">]
What is proplem ??
Thanks ,, [:">]
Re: please help me
Maybe you put too many items in your home.
In a new document, add just one piece of furniture and check if you can create a photo of it.
Re: please help me
Thank you very much ,,
It is o.k now ...
It is o.k now ...
Re: please help me
It was I can not creat photo only on fast ... but best Ican not specally when big size project ...
I can creat best photo only in samall project ...
I need creat best photo for big project ...
Is there any solution for this proplem ...
It is big proplem for me ..
I hope to excuse me to bad my languge ...
Thanks Puybaret
Sara ,,
Thanks Puybaret
Sara ,,
Re: please help me
It might be a memory size problem.
To increase memory size used by Sweet Home 3D up to 1024 MB, use the version with an installer, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the following text in that file:
and relaunch Sweet Home 3D.
-Xmx1024mand relaunch Sweet Home 3D.
Re: please help me
Emmanuel:
Would it be possible to include this as an option in Preferences ?
Re: please help me
That's a nice idea, but changing the maximum memory size used by Sweet Home 3D can't be done so easily. You have to change the -Xmx option in launch scripts: in some cases (like with Java Web Start and applets) that's simply not possible, and in other cases requesting too much memory could simply prevent Sweet Home 3D from launching.
Re: please help me
your suggestion is good ... Now , I can cerat photo even in big project ...
I have another proplem with imprt furniture some picture in http://www.model3d.biz/obj/?did=21
when I import them .. they are becam scattered and gray colour
Do you have any solution for this proplem ???
Puybaret ,, Thanks alot for help me ..
Re: please help me
Sara:
Think of OBJ as a language to describe a 3D model. As with real languages, there are plenty of dialects. Unfortunately not all dialects are the same. This can lead to incompatibilities when you try to import an OBJ model in SH3D.
Sometimes a workaround may help. Import the model in Blender , Misfit 3D or in Art Of Illusion . Then save or export the model again.
There is no guarantee, but sometimes this solves the problem.
