High priority dae
This topic has been viewed 5410 times and has 1 replies
leonidas187
Country: Türkiye
dae
Post by leonidas187 »
dae olarak kaydetme seçeneği çok güzel olur. obj olarak dışa aktardığımda lumion ve v-ray programlarında pencere içeriyi göstermiyor veya güneş yansıması olmuyor ve projede hiçbir değişiklik yapamıyorum. aslında sizde düz bir temel yerine orman içinde, deniz kenarında veya cadde ortasında gibi temeller hazırlarsanız çok güzel olur. şimdiden teşekkürler.
Re: dae
The 3D problems forum as well as the Wishlist forum are English language forums. I think your original (duplicate) post was on the Wishlist forum but because it is not in English it was moved to the Other languages forum. This post will probably be moved and/or merged with your initial post about DAE.
You get the most/best responses by translating to English and post in the English language forums. It is easier for one person to translate (you) than forcing every reader to translate. Many will not bother with it.
Then about your DAE exort wish. The DAE format is a complex XML format that can store more information than an OBJ file can. But... Sweet Home 3D cannot provide that extra information. It's virtually useless to export to DAE because it will not contain anything more than an OBJ export will contain.
If you really need the DAE format use Blender or an online service to convert the OBJ/MTL files to DAE. Remember, Sweet Home 3D is an interior design program, not a 3D modelling program like Blender.
