How to create workplaces for my kitchen
This topic has been viewed 5623 times and has 2 replies
sumsine
Post by sumsine »
Hallo,
can you help me? I want to create worktops for my kitchen with various shapes. How can I do that?
Thanks a lot
Sabine
Re: How to create workplaces for my kitchen
You will have to be a little more specific.
For simple tops you can resize a box. Use a stretched cylinder for a rounded border.
On my site under Kitchen2 there is a small library with replacement noses for kitchen tops that you can use. Or you can download the shapes library that has half cylinders and objects for the corners.
For random shapes the easiest way is to use a room. Draw and curve walls for the outside of the worktop you want. Double click inside to create a room. Select and export only the room, import it and adjust the height to what you want.
MarioSambol
Country: Croatia
Post by MarioSambol »
Creating an object using a created room is a very creative way. I'm surprised, I usually used some other software to do this. Apparently there is no need for that.
