SweetHome3D freezes all the time
This topic has been viewed 4431 times and has 3 replies
shyne
Post by shyne »
Apple M1 Pro + Sweet Home 7.5
I have to force it to quit because it starts to slow down after a time and freezes / hangs
Is there any known solution for that?
I hoped an update would help but it does not.
Plugins: https://ibb.co/21N5ZDJc
I did not have this issue at the beginning as far as I remember. My project is rather large.
Daniels118
Country: Italy
Re: SweetHome3D freezes all the time
Post by Daniels118 »
Try to get the console output, check from time to time to see if there are errors and post it here. To get the console output run the program from a terminal (this should be enough on Mac, but if you don't get any message try to redirect the output to a file as described here: https://www.sweethome3d.com/support/for ... 9906#46437 )
YGYL
Post by YGYL »
You said your project is quite large and then it gets stuck. Then I have experience~
Generally speaking, projects that are too large and complex and have too many objects will experience this problem. One of the most likely reasons is that you have turned on :Top view in plan objects and :Floor color or texture in plan room rendering.
Change Furniture icons in plan to Catalog icons.
Change Room rendering in plan: to Monochrome
Try to increase max memory as explained in the FAQ.
