Find and remove duplicate furniture
This topic has been viewed 9198 times and has 2 replies
MarioDLCO
Country: México
Post by MarioDLCO »
Good day everyone.
Does anyone have a plugin to find and be able to remove duplicate furniture? (that they are in the same position x, y, z).
Best regards!!!
Every Day is for Learn...
Re: Find and remove duplicate furniture
There is no such plugin.
But there are other ways to find them and you have to remove them yourself.
The bottom left panel is a list of all furniture in your plan. Right click in the list and you can add/remove displayed columns. Using this function you can add columns for x, y, and z. Make the list wider to get a good diaply off all columns.
If you didn't rename you furniture you can sort by name (click on the column header in the list) and check for identical xyz values for furniture with the same name.
Make sure you are have one level visible before you start checking. This is to make sure you are not seeing the same furniture at the same position but on a different level. Or make sure to also display the column for level so you can see the difference. Optionally you can also display the column for model size as an extra check or use it for sorting.
In the list you can select a double and press Delete to remove it.
MarioDLCO
Country: México
Post by MarioDLCO »
Thanks Keet.
I will try to develop the plugin.
Cheers.
