Multiple sloped wall with window
This topic has been viewed 3790 times and has 2 replies
gnarf
Country: Germany
Post by gnarf »
I also have a room with two different slopes on the outside wall, which also has a window. I absolutely can't figure it out. I've attached a (not so good) photo, maybe you can help me. THANKS!
selfbuild01
Country: Ireland
Re: Multiple sloped wall with window
Post by selfbuild01 »
My space has only 2ft high wall before it begins the roof slope. There are 3 velux on one side and 2 french dormers on the opposite slope. I've tried a few different ways but haven't mastered it it. If anyone can help I would really appreciate some clear instructions.
Thanks
Situations with these kinds of sloping walls are unique for each project. There is no generic solution for this, usually the slope is the bottom/underside of the roof you add.
If you want the slope independent of the roof you can use a thin box that you tilt and elevate. A thin box can close a sloping space without sticking out on the outside. Make all sides of the box invisible except the one that you see as the slope.
You can also use a triangle and make all sides except the slope invisible. Rotate and elevate as needed. The effect is the same as with a box.
