Automating the creation of walls, placement of doors,
This topic has been viewed 2675 times and has 8 replies
- MohanPathapata
- Country: India
Hello Team,
We have a use case where we need to upload a blueprint image as a background, and have the outer walls, inner walls, doors, and staircase automatically drawn in a 3D view, which can then be exported as a PNG format. Is this feasible through a custom plugin? The custom plugin should be smart enough to automatically calculate the dimensions of the outer walls, doors, and staircase. Alternatively, do we have any other way to automate this process? Thanks
Regards,
Mohan Pathapata
Regards,
Mohan Pathapata
Re: Automating the creation of walls, placement of doors,
There’s no plug-in able to do that.
- MohanPathapata
- Country: India
Thanks for your reply Emmanuel Puybaret,
Is there any other alternate approach to achieve that feature? Either as standalone application or a new custom plugin ? or any other approaches
Regards
Mohan Pathapata
Regards
Mohan Pathapata
If you know how to guess where walls and doors are placed in an image, feel free to create a plug-in able to create the matching objects with Sweet Home 3D API.
Good luck!
Good luck!
- MohanPathapata
- Country: India
So you mean to say if we are able to identify where the walls, doors and staircases need to be placed in the selected background image, then we can able to draw and place those objects(Walls, doors etc.) through API's ?
Regards
Mohan Pathapata
Regards
Mohan Pathapata
Yes, to create a wall, you have to create an instance of Wall class then add it to the Home instance returned by [font=courier new]getHome[/font] method in the plug-in you'll define.
For doors and staircases, you have to find the CatalogDoorOrWindow or CatalogPieceOfFurniture instance you want in the furniture catalog stored in user preferences, then use the catalog object to create a HomeDoorOrWindow or HomePieceOfFurniture instance, change its coordinates and size before adding it to the home instance with [font=courier new]addPieceOfFruniture[/font] method.
Objects added to home will appear in the plan and the 3D view accordingly.
- MohanPathapata
- Country: India
Okay, Thanks for the clarification. Before creating a walls and other objects. My custom plugin should read the uploaded background image to read coordinates. Do we have any option to do the same ?
Regards
Mohan Pathapata
Regards
Mohan Pathapata
Retrieve home controller instance with [font=courier new]getHomeContoller[/font] method in the plug-in, then you can let the user choose a file with the [font=courier new]showOpenDialog[/font] method available in the ContentManager instance bound to home controller.
Reading the content of the file as an image can be done with Java standard javax.imageio.ImageIO class.
MarioSambol
- Moderator
- Country: Croatia
It would be something like converting bitmap to vector in Coreldrw. With vector s, walls can easily be extruded in one of the 3D programs. But of course it doesn't work perfectly and architecture still requires precision. Mostly I think it's impossible to do.
