SweetHome 3D: 7.4
Macbook pro (Retina 15, Late 2013) I know it's old but still works well
MacOS 11.7.10
I made my floor plan and I want to create multiple pictures with different lights open to build my dashboard for Home Assistant...
Every time I change the light I want to be visible, the point of view changes and when I select "Go to Point of View", nothings happens.
Thanks in advance.
Go to point of view don't work
This topic has been viewed 4207 times and has 2 replies
Re: Go to point of view don't work
If you activated the Aerial view centered on selection option in the preferences pane, an Aerial point of view (stored or not) depends on the current selection. Either select again the same object(s) to get exactly the same point of view or use points of view in Virtual visit mode.
Thank you @puybaret, that fixed it.
Merci!
Merci!
