Is there a maximum size a plug-in can be added into the Sweet Home 3D project on SourceForge?
For a 15.5MB plug-in, I get the message: "413 Request Entity Too Large".
Maximum size of a plug-in
This topic has been viewed 8552 times and has 6 replies
EnkoNyito
Re: Maximum size of a plug-in
There are limits on file size: https://sourceforge.net/p/forge/documen ... ize-limits but this is probably not your problem. 15.5 MB should not be a problem.
Maybe it's related to this: https://sourceforge.net/p/seeddms/discu ... /133a634a/
I don't know how sourceforge is setup but maybe these instructions can help: https://popart-studio.medium.com/what-i ... 07fffdcc92 (heading "Modifying the PHP ini File")
- Daniels118
- Country: Italy
You could also try to compress the jar with a higher compression level to shrink its size. By the way I'm curious about what make your plugin so large.
I don’t have access to this kind of parameters on SourceForge, but they already increased the size limit of attached files in the past. If you want to make your plug-in smaller, you could compile your class files without debug information (Enkonyito already zip them). His plug-ins are large because they include YafaRay DLLs.
Enkonyito, if you don’t find a solution on SourceForge, send it to me, I’ll host your plug-in on sweethome3d.com server.
- Daniels118
- Country: Italy
But considering that yafaray dll is now part of SH3D itself, I see no pratical reason to include it in the plugin. It could worth to think about it.
@Puybaret
Thanks for the suggestion, it might be useful in the future.
For the moment, I applied this solution.
@Daniels118
Unfortunately, using the DLLs of the version of YafaRay integrated into Sweet Home 3D causes the error
@Daniels118
java.lang.UnsatisfiedLinkError: YafarayRenderer.createEnvironment(Ljava/lang/String;Ljava/lang/String;)JEnkoNyito
- Daniels118
- Country: Italy
You should try to not call initdll at all, they are already loaded.
