Roofs
This topic has been viewed 2195 times and has 7 replies
Guemax
Country: Germany
Roofs
Post by Guemax »
How can I install pitched roofs with dormers if the roof is above 2 levels? It doesn't work with walls because you can't specify a pitch. And I would also like to install several Velux windows in the attic.
Thanks for helping me....
Re: Roofs
Assuming you already installed the Generate Roof plugin check out this topic describing dormers and integrating Velux windows:
https://www.sweethome3d.com/support/for ... ,190#60535
Don't forget to install the special window library Dorin created to integrate the windows in the roof.
That the roof is above 2 levels doesn't make a difference. After generating it's another object you can move to another level or give a different elevation. That way you should be able to place it where you need it.
Guemax
Country: Germany
Re: Roofs
Post by Guemax »
Thank you very much. I will try and do my best.
Best regards from the south of France
Guemax
Country: Germany
Re: Roofs
Post by Guemax »
Once more another question. I downloaded the plugin and it seemed ok, but nothing indicated in the menu. Does it need the Enbglish version for the plugin? I am working with the German one.
Re: Roofs
I assume you mean the Generate Roof plugin. To generate a roof the plugin needs a room that is selected. A roof is generated using the points of the room.
After the roof is generated you can also select the generated roof to restart the plugin to make changes to the roof, the room is no longer needed unless you want to use it again to generate a new roof.
You can save the room in another level that you make invisible since it is probably a room that is not used as the floor of the house. The room to generate a roof usually extends outside the walls to get an overhang of the roof.
Guemax
Country: Germany
Re: Roofs
Post by Guemax »
Hi Keet,
I am sorry, but I have to bother you again. I try to be as precise as possible.
I created a test room to keep it simple. 4 walls, 1 of them 1,5m, another 2,5m, the sides corresponding.
The plugin was indicated as installed, effective after relaunch, which I did.
Then I clicked on the room to find any sign of a roof application. No way. Neither when I double clicked, nor when I opened the room window with the right mouse key.
Can you help?
I would appreciate if you could take the time to explain exactly what to do.
Remark: the plugin seems to be English, and I am working with a German version. Would it help to change?
Thank you very much
Re: Roofs
If you installed the plugin correctly you should see a grayed out "Generate roof" item under the Tools menu. When you select a room that item should be available to start the Roof plugin.
sjb007
Re: Roofs
Post by sjb007 »
No, not walls, create and select a room.
Icons at the top:
Select Pointer
Pan Hand
Add Wall
Add Room
(Or in German "Raum estellen")
Once the room is created, use the Select Pointer to select the room, then use Tools -> Generate roof...
