How i can change my texture brick color?
This topic has been viewed 1785 times and has 4 replies
MatheusNegrini
- Country: Brasil
Hi people, i need change a texture brick color, like a brick change a color to white (for example) but maintein the texture of the brick, if i trie set a texture and change a color in "switch walls" tool, the wall chage your's texture, i need maintein the texture
Re: How i can change my texture brick color?
A texture is an image that is applied to the wall. To change the color of the texture you will have to change the color of the image.
If you don't have the texture image as a file you can export the wall. One of the resulting files that is created is the texture image. Modify the image with a program like GIMP and import it as the new texture for your wall.
MatheusNegrini
- Country: Brasil
Tanks i will try it, have a nice day!
Maybe this blog's article will help you: http://www.sweethome3d.com/blog/2016/01 ... xture.html
- captaincook
- Country: France
Bonjour.
Vous pouvez aussi regarder sur ce site si vous trouvez ce que vous cherchez. Exemple pour des briques blanches.
https://www.sketchuptextureclub.com/tex ... ite-bricks
Le choix de textures en tous genres est énorme.
Le téléchargement est gratuit pour la plupart. Il faut juste se créer un compte.
