Help with rendering
This topic has been viewed 4744 times and has 7 replies
crackwood01
Country: Canada
Help with rendering
Post by crackwood01 »
i'm getting rendering problems, is there something i can do
the door looks gray and the quality looks blured
config:
AMD Ryzen 5 5600g
windows 11 pro
x64
32gb ram
gpu g-force rtx 3060 12gb vram
DigitAle.Com
Country: Italia
Re: Help with rendering
Post by DigitAle.Com »
hello, since I often have the same problem, but I'm not an expert in SH3D, I'm using the workaround to waste some time to perform tests adding light sources, not visible but It resolves the problem of greysh stuff. I mean waste of time to find a good position and the right percentage of light setting...
I don't think SH3D is using GPU acceleration, (not in my case) just be sure to use the 64 bit release (asked while installing the app.
Then use a higher resolution while rendering, 1280 or 1600 x ...
It takes time... I know. I use YafaRay rendering engine at 4th quality level, then go for a beer, a sandwich or a cigarette... SunFlow seems to be slower to me and creating unwanted white shiny bubbles... but agan, wait for expert users answers. Good Luck.
Alessandro
I can see two problems:
1 - the door - this seems to be a Sketchup model. When not all faces are textured, SH3D has problems similar to what we see. Make sure (using Sketchup) that your model has textures on all faces (inside and out) before exporting the model.
2 - black spots in ceiling lights - this is caused by light bulbs touching the ceiling. Lower the light bulbs and the black spots disappear.
crackwood01
Country: Canada
Thanks for the reply,
I will give it a try
About the door, you could also make invisible the materials of the inner faces of the furniture (must be the materials named "material").
crackwood01
Country: Canada
thank you all,
worked perfectly ;)
crackwood01
Country: Canada
sjb007
Post by sjb007 »
DAMN!!! That's a nice jump in quality. [=D>]
