applause Synchronisation iCloud
This topic has been viewed 4648 times and has 2 replies
Thomas_H
Country: Germany
Post by Thomas_H »
I recognized that there is now an app for the iPad.
Is there a synchronisation between the Mac desktop.app and the iPad.app?
Thanks in advance.
Re: Synchronisation iCloud
I've just checked but the current solution isn't perfect.
Files are compatible between apps, but under iOS, you can't save directly a file in iCloud drive. When you tap on Save button then Export button, the edited home is saved in SweetHome3D folder, and you'll have to copy it to iCloud drive afterwards with Files app. Opening a file found in iCloud drive is more simple: tap on Open button then Import button and select the file you want.
Thomas_H
Country: Germany
Post by Thomas_H »
Thanks for your reply, that sounds like a workable workaround.
In addition, it would be good if you could further expand the integration of iCloud.
Can you take this topic with you, or should I post it somewhere else still as a feature request?
