Hi, please do you know where is the problem? I imported the scan of the real plan ground floor and built the wals. In the first floor I can also move with the wals from the ground floor and it is wrong. I can´t cath the walls from the first floor properly, they mix together with the ground walls. When i did floors withhout the imported backround of the plan, its ok. In every floor I can move only with the walls, which are built on the concrete level.
Thank you for any idea!
Imported backround and problems with levels
This topic has been viewed 2387 times and has 1 replies
Re: Imported backround and problems with levels
The problem is most likely incorrect wall/level heights.
Set the level height of level 0 to the same height as your walls on level 0 (right click on the level tab to edit level properties).
Check the floor thickness you have on level 1. Level 1 elevation must start at the height of level 0 + the floor thickness.
Example:
level 0: walls 250 high, set level height 250
level 1: walls 250 high and floor thickness 20: level 1 elevation 250+20=270, level height 250.
Example:
