High priority The problem with the late display of furniture
This topic has been viewed 2861 times and has 3 replies
vasilisa123
Country: USA
Post by vasilisa123 »
The furniture in the lower field of the program is not displayed immediately, but only after I add the next furniture after it. And after moving the furniture completely disappears. This is very strange and needs to be fixed somehow. The problem occurs both when installing the latest version of the program and on older versions. I haven't used the program on my laptop before. Geforce 940 MX graphics card.
If I use the online version of the program, there are no problems, but I would like to work offline.
Re: The problem with the late display of furniture
This kind of bug may leave some traces in the console output.
If you’re under Windows, please run cmd, drag and drop SweetHome3D.exe in the cmd window, add a space and the parameter 2> output.txt, type return key and try to reproduce the bug.
This will create an [font=courier new]output.txt[/font] file that you can share or [url=mailto:[email protected]]send to me[/url] .
vasilisa123
Country: USA
I sent the contents of the file to the address you specified [email protected]
vasilisa123
Country: USA
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/C:/Program%20Files/Sweet%20Home%203D/lib/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
