HI,
I am using one of the picture frames in a room. Is there a way to switch the picture used in the frame for one of my own personal picture?
Thanks
Own picture into picture frame
This topic has been viewed 6442 times and has 4 replies
DawnC86548
- Member
- Country: USA
Re: Own picture into picture frame
This video should help you.
DawnC86548
- Member
- Country: USA
thank you!!
If it’s a standard picture frame, you should be able to just pop the back open and swap out the image for your own.
@Nayborex
You are responding to a very old post. The question was not about a real picture frame but a 3D model as used in Sweet Home 3D.
In most cases changing the picture is simply replacing the texture for the picture with you own jpg/png image. Just make sure that the scale is the same as the original picture.
