Hi there -
I'd like to send the floor plan I've created of my house to a designer who does not use SweetHome3D. Is there a way to export an image that includes all of the dimensions I've input so that anyone can view it?
Thanks,
Adam
Exporting FloorPlan with Dimensions
This topic has been viewed 19456 times and has 4 replies
- Daniels118
- Country: Italy
Re: Exporting FloorPlan with Dimensions
Maybe the Auto Dimensioning plugin can do what you want.
- dorin
1. Set printing: File->Page setup...
2. Print to PDF: File->Print to PDF...
3. Send the PDF file.
MarioSambol
- Moderator
- Country: Croatia
The easiest way to get a plan with dimensions is to make a Printscreen with the PrtScr key on the keyboard. Not the entire screen but just the selected part with the mouse. The image is located in the Scrennshot directory.
- dorin
My previous answer is useful when you need to export the plan with scale.
Wile you have specified already the dimensions, the plan scale isn't mandatory.
For this purpose exist ExportPlanImage plugin.
After install you will find it under Tools menu.
It can export the plan (selected level) as .PNG or .JPEG at different qualities.
