Create Rooms with Walls
This topic has been viewed 2858 times and has 2 replies
How does the user create a room with walls at the same time? Using Create Room seems to leave off the walls.
Re: Create Rooms with Walls
It’s not possible, but using the wall creation tool, you can create the walls around a room, by double clicking on it.
After a little trial and error, and with your tip, I was able to figure it out.
1. Use Create Rooms button, and create the room.
2. Then select the Create Walls button, and only then double-click on the room.
The user could double-click all day if not choosing the correct icon button.
Thanks for the tip. I will add this to my how-to article.
_____________________________________________________________
By the way, I tried to post this and got an error from your server:
HTTP Status 403 – Forbidden
Type Status Report
Message Spamming IP address detected
Description The server understood the request but refuses to authorize it.
Apache Tomcat/9.0.31 (Debian)
I had to change browsers.
Type Status Report
