High priority Furniture and objects are just the outline
This topic has been viewed 5967 times and has 2 replies
samturnermpls
Country: United States
Post by samturnermpls »
I've used the software for a very long time and suddenly all of my drawings have the same issue. The objects don't show up, export or print like they use to, they are now just outlines with no dimension, color or texture. I have tried everything and cannot find any sort of similar issue, I hope someone can help.
Sam
Re: Furniture and objects are just the outline
Without images, it’s difficult to be sure but your issue could be due to the recent bug described here coming from a regression in AMD driver. If it’s the case, install driver version 22.5.1 to go back to a working solution or run the program in 32 bit with DirectX if you don’t need too much memory (see FAQ).
samturnermpls
That was the solution, after rolling back the driver it is working correctly. Thanks!
