"Create photo" crashes
This topic has been viewed 3967 times and has 9 replies
millennium_y2k
In my version 6.1.1 when I go to create a 3D photo of the house, full resolution, I click on "Create", the rendering starts, but at a certain point it stops, without errors... what can it depend on?
Re: "Create photo" crashes
Maybe, your SH3D file is too large or the program doesn't have enough memory to create the image. See the FAQ to increase the maximum memory Sweet Home 3D can use, but if you use the 32 bit version (see About dialog box), try first the 64 bit version by running again the installer.
millennium_y2k
i use a mac bok, the file is layered and weighs 60mb, but when i did it 1 year ago, everything was fine...
millennium_y2k
I'm also trying with the latest version, 7.0.2, but a red X comes out in the preview... do i need to install anything else, maybe java?
No need to install Java. You certainly changed something.
Maybe try another renderer (YafaRay instead of SunFlow).
millennium_y2k
The project is from 1 year ago, done on another MAC.
I'm not sure if I imported all libraries with objects, could that be it? The render both with YafaRay and with SunFlow, doesn't start, it shows the red X or nothing.. I tried both on MAC and on Win11.
Is there any way to know if libraries are missing (if this were the case)?
THK !
THK !
A SH3D file contains everything it needs to be displayed and rendered.
Send [url=mailto:[email protected]]me[/url] your file, I'll have a look to it.
millennium_y2k
Email send
Thanks for your file.
I didn't experience any crash during the rendering of your file with SunFlow or YafaRay renderers, but I had to be very patient before YafaRay starts. For sure, it needs a lot of memory to render it, because of the items named "prato" showing many grass blades.
If you don't have the patience to wait or increase the max memory, you could replace these items by rooms showing a grass texture.
millennium_y2k
Thanks a lot, I will try with your suggestion!
