confused Stairs don't reach the wall height
This topic has been viewed 4073 times and has 6 replies
FlaStorm32
Country: USA
Post by FlaStorm32 »
I created a 2-level structure with doors on the second level. 8 foot walls. When I try to add the Exterior Stairs, they do not match the wall height. When I adjust the height, I get huge railings. A straight stair will fit correctly, but I need the landing at the top.
https://postimg.cc/Nyw6wNP5
Thanks!
FlaStorm32
Country: USA
Re: Stairs don't reach the wall height
I tried the staircase generator, but it doesn't allow for an upper landing. Otherwise, the stair fit well enough.
kawal
Country: India
Post by kawal »
I also had the same problem. I made every step of the stair and landing manually using the box. I picked the box, kept the length 36", thread 10" and riser 6" and with different elevation for every stair I built my own and later grouped all together.
cadilhac
Country: United States
Post by cadilhac »
The Staircase Generator does have an option for staircase with landing, doesn't it? Tweaking the numbers therein, you can put the landing at the top:
FlaStorm32
Country: USA
Straight with Landing showed me a Bottom landing, so I passed it up. Will have to work with it more. Thanks!
MichaelS1950
Post by MichaelS1950 »
Newbie here. Just bought the software today.
I'm looking for a stair with a landing almost like the picture except with the rail on one side.
My question is where do I find the stair generator? Is it an add on?
Thanks very much.
The Staircase generator is a plug-in available here.
