I created a house with a level 0 and a level 1. For the exterior walls of the house, I simply extended them the full height from level 0 up into level 1.
However, I also created a balcony that wraps around level 1 by creating walls and a room within those walls. I can see what the house itself will look like in 3d at either level.
But if I use 3d at level 0 to do a virtual visit, the balcony doesn't show up at all, neither its walls nor floor. I can only see them from level 1.
Any suggestions on what I am doing wrong here? I want to be able to see the balconies when I am looking up from outside on level 0.
can't see balconies on level 1 from level 0
This topic has been viewed 3162 times and has 1 replies
Re: can't see balconies on level 1 from level 0
Never mind, I seem to have had this problem before in a different context but the solution also worked here: http://www.sweethome3d.com/support/foru ... read,11421
