What Is Magnetism
This topic has been viewed 5605 times and has 7 replies
What Is Magnetism
Is magnetism the same as snap-to? It sure looks that way from the video tutorial.
Re: What Is Magnetism
Magnetism doesn't snap to the grid. Otherwise, please search for magnetism in the help, it's cited in many pages!
Yes, you are correct that the word shows up multiple times. However, it is not defined in its function nor in relationship to snapping to a grid; which is a reasonable expectation. The novel way it is used in the program dictates a need for a definition.
Magnetism is between objects. Snap-to-grid is not magnetism, but as you stated yourself, snapping to the grid [:)]However, it is not defined in its function nor in relationship to snapping to a grid; which is a reasonable expectation.
I'm not aware of any program where snap-to-grid is called magnetism.
So the use of "magnetism" in this program is where one object is attracted to another.
Can you explain the use of such a feature? Is it like a chair to a table, or is it like the end of one line to the end of another?
The most common occurance is where doors and windows slip into a wall and adjust themselves to the wall thickness.
If you drag furniture against a wall it sticks and orientates against the wall so you don't have to manually fit it against the wall.
Objects can also be dragged against each other and have a magnetism point where they 'stick' together, also for easy placement.
Magnetism also causes furniture rotation and wall angles to occur in steps of 15°.
If you switch magnetism off you can set any angle, place doors and windows without deforming into a wall, and move objects over each other without sticking against each other. This is all with mouse movement. When using the arrow keys magnetism is ignored.
Thank you for the good info and explanation. This makes it easier for all.
Yes thanks for explanation!
