home 3D view not working when executing the JAR file
This topic has been viewed 2831 times and has 2 replies
Dennisek
Country: Germany
Post by Dennisek »
Hello guys, I just recently discovered Sweet Home 3D. The program seems to be working fine when I execute the file SweetHome3D (Linux) but when I execute the JAR file then the home 3D view (the down right screen) is not working. Since I want to create plugins I am interested in being able to have a functioning JAR version of Sweet Home 3D.
When I execute the JAR file I get the following messages on the command line:
Caught AppContextInfo(Bug 1004) InaccessibleObjectException: Unable to make public static sun.awt.AppContext sun.awt.AppContext.getAppContext() accessible: module java.desktop does not "exports sun.awt" to unnamed module @5eb5c224 on thread J3D-Renderer-1     [0]: java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:354)     [1]: java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297)     [2]: java.base/java.lang.reflect.Method.checkCanSetAccessible(Method.java:200)     [3]: java.base/java.lang.reflect.Method.setAccessible(Method.java:194)     [4]: com.jogamp.nativewindow.awt.AppContextInfo$1$1.run(AppContextInfo.java:40)     [5]: com.jogamp.common.util.UnsafeUtil.doWithoutIllegalAccessLogger(UnsafeUtil.java:219)     [6]: com.jogamp.nativewindow.awt.AppContextInfo$1.run(AppContextInfo.java:34)     [7]: java.base/java.security.AccessController.doPrivileged(AccessController.java:318)     [8]: com.jogamp.nativewindow.awt.AppContextInfo.<clinit>(AppContextInfo.java:31)     [9]: com.jogamp.nativewindow.awt.JAWTWindow.<init>(JAWTWindow.java:128)     [10]: jogamp.nativewindow.jawt.x11.X11JAWTWindow.<init>(X11JAWTWindow.java:60)     [11]: java.base/jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:67)     [12]: java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)     [13]: java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:483)     [14]: jogamp.nativewindow.NativeWindowFactoryImpl.getAWTNativeWindow(NativeWindowFactoryImpl.java:105)     [15]: jogamp.nativewindow.NativeWindowFactoryImpl.getNativeWindowImpl(NativeWindowFactoryImpl.java:66)     [16]: com.jogamp.nativewindow.NativeWindowFactory.getNativeWindow(NativeWindowFactory.java:654)     [17]: javax.media.j3d.JoglPipeline$QueryCanvas.addNotify(JoglPipeline.java:8604)     [18]: java.desktop/java.awt.Container.addNotify(Container.java:2804)     [19]: java.desktop/java.awt.Window.addNotify(Window.java:791)     [20]: java.desktop/java.awt.Frame.addNotify(Frame.java:495)     [21]: java.desktop/java.awt.Window.show(Window.java:1053)     [22]: java.desktop/java.awt.Component.show(Component.java:1729)     [23]: java.desktop/java.awt.Component.setVisible(Component.java:1676)     [24]: java.desktop/java.awt.Window.setVisible(Window.java:1036)     [25]: javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8379)     [26]: javax.media.j3d.Renderer.doWork(Renderer.java:496)     [27]: javax.media.j3d.J3dThread.run(J3dThread.java:271) Caught AppContextInfo(Bug 1004) IllegalAccessException: class com.jogamp.nativewindow.awt.AppContextInfo cannot access class sun.awt.AppContext (in module java.desktop) because module java.desktop does not export sun.awt to unnamed module @5eb5c224 on thread J3D-Renderer-1     [0]: java.base/jdk.internal.reflect.Reflection.newIllegalAccessException(Reflection.java:394)     [1]: java.base/java.lang.reflect.AccessibleObject.checkAccess(AccessibleObject.java:674)     [2]: java.base/java.lang.reflect.Method.invoke(Method.java:568)     [3]: com.jogamp.nativewindow.awt.AppContextInfo.fetchAppContext(AppContextInfo.java:191)     [4]: com.jogamp.nativewindow.awt.AppContextInfo.update(AppContextInfo.java:135)     [5]: com.jogamp.nativewindow.awt.AppContextInfo.<init>(AppContextInfo.java:50)     [6]: com.jogamp.nativewindow.awt.JAWTWindow.<init>(JAWTWindow.java:128)     [7]: jogamp.nativewindow.jawt.x11.X11JAWTWindow.<init>(X11JAWTWindow.java:60)     [8]: java.base/jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:67)     [9]: java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)     [10]: java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:483)     [11]: jogamp.nativewindow.NativeWindowFactoryImpl.getAWTNativeWindow(NativeWindowFactoryImpl.java:105)     [12]: jogamp.nativewindow.NativeWindowFactoryImpl.getNativeWindowImpl(NativeWindowFactoryImpl.java:66)     [13]: com.jogamp.nativewindow.NativeWindowFactory.getNativeWindow(NativeWindowFactory.java:654)     [14]: javax.media.j3d.JoglPipeline$QueryCanvas.addNotify(JoglPipeline.java:8604)     [15]: java.desktop/java.awt.Container.addNotify(Container.java:2804)     [16]: java.desktop/java.awt.Window.addNotify(Window.java:791)     [17]: java.desktop/java.awt.Frame.addNotify(Frame.java:495)     [18]: java.desktop/java.awt.Window.show(Window.java:1053)     [19]: java.desktop/java.awt.Component.show(Component.java:1729)     [20]: java.desktop/java.awt.Component.setVisible(Component.java:1676)     [21]: java.desktop/java.awt.Window.setVisible(Window.java:1036)     [22]: javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8379)     [23]: javax.media.j3d.Renderer.doWork(Renderer.java:496)     [24]: javax.media.j3d.J3dThread.run(J3dThread.java:271) Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.IllegalAccessException: class javax.media.j3d.JoglPipeline cannot access class sun.awt.X11GraphicsDevice (in module java.desktop) because module java.desktop does not export sun.awt to unnamed module @5eb5c224 	at javax.media.j3d.JoglPipeline.getScreen(JoglPipeline.java:8553) 	at javax.media.j3d.Screen3D.<init>(Screen3D.java:354) 	at javax.media.j3d.Canvas3D.<init>(Canvas3D.java:1124) 	at javax.media.j3d.Canvas3D.<init>(Canvas3D.java:1026) 	at javax.media.j3d.Canvas3D.<init>(Canvas3D.java:1016) 	at com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D.<init>(Unknown Source) 	at com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D.<init>(Unknown Source) 	at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source) 	at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source) 	at com.eteks.sweethome3d.swing.HomeComponent3D.createComponent3D(Unknown Source) 	at com.eteks.sweethome3d.swing.HomeComponent3D.access$200(Unknown Source) 	at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source) 	at java.desktop/javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:86) 	at java.desktop/javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:193) 	at java.desktop/java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:188) 	at java.desktop/java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:187) 	at java.desktop/java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:187) 	at java.desktop/java.awt.Component.processComponentEvent(Component.java:6448) 	at java.desktop/java.awt.Component.processEvent(Component.java:6396) 	at java.desktop/java.awt.Container.processEvent(Container.java:2266) 	at java.desktop/java.awt.Window.processEvent(Window.java:2056) 	at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:4991) 	at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2324) 	at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2780) 	at java.desktop/java.awt.Component.dispatchEvent(Component.java:4823) 	at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:775) 	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720) 	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714) 	at java.base/java.security.AccessController.doPrivileged(AccessController.java:399) 	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) 	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:97) 	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:747) 	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745) 	at java.base/java.security.AccessController.doPrivileged(AccessController.java:399) 	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) 	at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:744) 	at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203) 	at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124) 	at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113) 	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109) 	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) 	at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Caused by: java.lang.IllegalAccessException: class javax.media.j3d.JoglPipeline cannot access class sun.awt.X11GraphicsDevice (in module java.desktop) because module java.desktop does not export sun.awt to unnamed module @5eb5c224 	at java.base/jdk.internal.reflect.Reflection.newIllegalAccessException(Reflection.java:394) 	at java.base/java.lang.reflect.AccessibleObject.checkAccess(AccessibleObject.java:674) 	at java.base/java.lang.reflect.Method.invoke(Method.java:568) 	at javax.media.j3d.JoglPipeline.getScreen(JoglPipeline.java:8551) 	... 41 more
I hope these informations are helpful for solving my problem.
Best regards,
Dennis
Re: home 3D view not working when executing the JAR file
You may have tried with a recent version of Java. Try an older version <= 15.
Dennisek
Country: Germany
Post by Dennisek »
Thank you very much! Yes, with Java version 8 it's working! :)
