Hello everyone
Imported *.3ds , *.obj , *.dae files do not work as usual. Or I couldn't.
for example ;
I found a window model. I wanted to use this on the wall. but it does not automatically split the wall and settle. what is the reason of this ?
thanks.
imported furniture
This topic has been viewed 3995 times and has 2 replies
Re: imported furniture
It will work correctly if you pay attention to select the option Door or window at the third step of the furniture import wizard.
Thank you. OK, I did. [:)]
