Hello Forum,
Im new here and I use this fantastic Software to "build" houses who are may been extinguished soon for privat documentation only ( may one day some kids like to see it). Righ now i re-create by photos a wodden house who sits in a demolish area of Whuhan, China.
Not a lot i can use out of the libary, must create a lot items by hand and i dont have 3-D software because of my poor laptop.
Right now i like to build a living room shelve as it is. (swwet 60`).
My problem is, it has round edges and i dont find half-cylinder to create this. I used normal cylinder and tryed to "cut" with invisible boxes, dosent work. Also the shelf has a square hole i tryed with invisibel box and service hatsch- bothe dosent create a hole in the cylinder.
Who can halp me with some advice? would like to publish picture of original and so-far creation and the house, but.. i dint know how. looks like it is a big task to display the own work here, please send your advice !
May i can send pictures by email?!
Thanks to all!
Need Pro-Help!
This topic has been viewed 6717 times and has 14 replies
Need Pro-Help!
Laptop :ThinkPad 490, WIN11Pro, 64Bit, 8GBRam, 6T Harddrive
Never give Up!
Never give Up!
Re: Need Pro-Help!
SweetHome3D is not a modelling tool. It is very difficult to model anything new unless it is very simple.
If your laptop can run SH3D, it can run Blender. some parts of blender are very hard on the computer. The kind of things you will want to model will not be hard for your laptop. So, my advice is: download, and do some tutorials on Blender.
This thread answers how to get your images displaying inside the forum using MediaFire: http://www.sweethome3d.com/support/foru ... hread,1886
Or you can post a link to an online image. I have posted shared Google Drive links before, that people can click on and view. You are in China, so it is not clear what image hosting services you are able to use.
Re: Need Pro-Help!
No Googel service works at all in China. And to create an account on chines platform you need a chinese ID. I dont have. the internet restrictions for expats are higher and higher.
Never give Up!
Never give Up!
Re: Need Pro-Help!
Maybe this works:
- draw very thin walls in the shape of your shelf, you can also make rounded corners
- set the walls to a height of a few centimetres, corresponding to the thickness of your shelf
- insert a room
- delete the walls, then export and import the room
- this should give you the desired shelf
- insert a room
Re: Need Pro-Help!
For the square hole in the shelf you can export a box with the size of the hole and import it as a staircase. This will cut the hole in the room you created after following what hansmex suggested. Then select only the room for export and it should keep the hole.
Re: Need Pro-Help!
@Hansmex
Wow! Vielen Dank! der Tipp ist überragend gut. Hat prima geklappt. Würde dir gerne ein Bild der ersten Lösung senden. oder vom Haus. ist ein sehr komplexes Ding da es ein Haus darstellt welches vor rund 100Jahren in China gebaut wurde. Ist mein Hobby. bin da nun 6 monate dran- und nicht fertig. Alle Informationen kommen von Fotos die ich gemacht hatte.
Never give Up!
Never give Up!
Re: Need Pro-Help!
Sende mir deine Photo und mit deine Genehmigung werde ich es hier publizieren.
Re: Need Pro-Help!
@Hansmex
Vielen Dank wede ich gleich machen- 1. mail ist raus
Never give Up!
Never give Up!
Re: Need Pro-Help!
Below you find two images T_R sent me for publication.
First a picture of the real stuff
And here is the same in SH3D
Re: Need Pro-Help!
Thank you Hansmex!
Never give Up!
Never give Up!
