Bug?: home plan doesn't update when plugin resizes furniture
This topic has been viewed 4288 times and has 1 replies
adoberito
Post by adoberito »
I've encountered what seems to be a bug, where when I have a plugin modify the size of a HomePieceOfFurniture, it correctly updates everywhere except in the home plan view.
For example, if my plugin says:
HomePieceOfFurniture projector = // ...
projector.setDepth(1000);
home.addPieceOfFurniture(projector);
The projector seems very stretched in the home 3D view, but appears as its default dimensions in the home plan view.
If I then double-click it and go to the "Modify furniture" window, the correct (large) depth is visible. If I make some other change to the dimensions (for example changing the height), when I click "OK" the depth is now correct in the home plan view.
If this is a bug, I assume you'll fix it in a later version. I'm using a version provided by Debian, so it'll probably be a long time for a fix. Is there some workaround I can use in the meantime to force the home plan view to recalculate the dimensions?
Thanks!
Re: Bug?: home plan doesn't update when plugin resizes furniture
The size used to display a piece of furniture in the plan is actually coming from the values returned by the methods [font=courier new]getWidthInPlan[/font] and [font=courier new]getDeprhInPlan[/font] which may return values different from [font=courier new]getWidth[/font] and [font=courier new]getDeprh[/font] if the piece is rotated around a horizontal axis.
As this size in the plan is automatically updated by the plan controller on any piece added to the edited home, you could simply call [font=courier new]addPieceOfFurniture[/font] before [font=courier new]setDepth[/font]. If you prefer not to change the order of these calls, you’ll have to call [font=courier new]projector.setDepthInPlan(1000)[/font] after calling [font=courier new]setDepth[/font].
If possible, it would be nice to explain what you want to achieve [:)]
