Delete background image
This topic has been viewed 3919 times and has 3 replies
catalpa34
Country: Australia
Post by catalpa34 »
I've been trying to solve this for some time and I've read all the posts here I can find. Every time I create a new level, it has a background image automatically. How do I stop this behaviour?
Re: Delete background image
A level uses the same background image as the previous level if they are at the same elevation. If you change its order with the arrows at the right of the levels table shown in the Level modification dialog, it won't display it anymore. You could also change its elevation adding a very small value like 0.001 cm.
catalpa34
Country: Australia
Post by catalpa34 »
I'm actually thinking it's not a background image, but more like some sort of waterwark. I have two levels with a background image, which covers the watermark. I'f I hide the background image, then I can see the watermark.
Country: UK
Post by Mike53 »
Could it be shadow lines of walls on other levels you are seeing is it?
