Thickness of the wall
This topic has been viewed 2367 times and has 4 replies
rotoped123
Post by rotoped123 »
Hi, I'm a newbie and would need an explanation of drawing walls and surfaces.
I draw the surface of a room and I want to draw the walls but with different thicknesses. When I change the thickness, the floor creeps into the wall. Then I get different dimensions and room area. Where am I going wrong?
THX
Re: Thickness of the wall
Walls and rooms are not bound. Just move the the room corners afterwards.
rotoped123
So you recommend me.... paint walls with my thickness and after that create a room? Can you recommend any video with basic creating room and wall?
rotoped123
When I move the wall to the corner......it is not exact. Maybe I describe what I want to. I want to create a blueprint of the flat - walls, surface, area of the floor with cote. It is enough for me.
sjb007
Post by sjb007 »
Draw your walls first. Set their thicknesses as required. Position them exactly where you want. Switch to the room tool and double-click in the space between the walls. SH3D will fill the empty area with a room automatically provided it is an enclosed space. i.e. do not leave gaps in the perimeter. Door objects do not count as gaps.
