Disable Autoupdate
This topic has been viewed 9128 times and has 6 replies
Disable Autoupdate
We use the silent installation. Is it possible to deactivate the autoupdate option with a command within the silent installation, without doing it manually?
Re: Disable Autoupdate
If by autoupdate option, you mean the option in preferences that allows to check if some updates are available (it just checks and won't update the program), it's not possible without changing and recompiling the program.
Why not using the last version so this dialog box won't appear?
Thanks for the information. We use a reborn-solution, so that the uses are not able to make any changes at the system, including the updates. So the dialog box only disturb.
I'll see if I can add this feature in a coming version.
That would be great, thanks.
Please try the new [font=courier new]/checkUpdatesDisabled[/font] argument I added to Windows installer in version 7.0.
It works perfect - thanks!
