rose High priority Sweethome3d
This topic has been viewed 7125 times and has 6 replies
abajwa
Country: Bolzano, Bolzano, Italy
Sweethome3d
Post by abajwa »
Bother when i load the java main class then i receive this kind of error. please help me ASAP.
Nov 10, 2009 2:16:39 PM javax.media.j3d.NativePipeline getSupportedOglVendor
SEVERE: java.lang.UnsatisfiedLinkError: no j3dcore-ogl-chk in java.library.path
Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1682)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1030)
at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231)
at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200)
at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:158)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:63)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:75)
at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:449)
at com.eteks.sweethome3d.SweetHome3D.createApplication(SweetHome3D.java:389)
at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:196)
Re: Sweethome3d
How did you launch Sweet Home 3D?
If you build yourself Sweet Home 3D from the sources, did you read the part of the README.TXT file that mentions "java.ext.dirs"?
By the way, please no "ASAP" in messages. Support is free, so don't ask too much.
meleonid
Country: SIMFEROPOL, CRIMEA, UKRAINE
Re: Sweethome3d
Post by meleonid »
For newbies like me: please make sure that your're using JRE5. I recieve exception above on JRE6 even with VM parameters from Readme.txt specified. With JRE5 everything works OK.
Re: Sweethome3d
Leonid, sorry to contradict you, but it works with Java 6 too.
meleonid
Re: Sweethome3d
Post by meleonid »
Emmanuel, that's good! Looks like I did something wrong, because SH3D didn't passed about 10 unit tests and didn't started UI because of error above until I reconfigured it to Java 1.5 VM :(
Anyway, now it works great!
Cardinal
Re: Sweethome3d
Post by Cardinal »
I have the same stacktrace reported above. I've tried adding the VM argument as described in the readme file with no success. When I do this I get a different stacktrace but the same Exception :
I am totally unfamiliar to Java 3D so I'm wondering if there's anything in particular I need to do (download? install?) prior to trying to run SH3D on eclipse?
Thanks in advance.
Cardinal
Re: Sweethome3d
Post by Cardinal »
Well I restarted eclipse and somehow it works. Sorry for the trouble.
