Door height is different in XML when model is saved
This topic has been viewed 2465 times and has 2 replies
workingstorage
Post by workingstorage »
I have a door that I set in the software to 83.188 inches high, which is 207.97cm.
When I check that same door in the Home.xml, it's showing a height of 211.29625.
I'm trying to generate code to place in the XML so it comes through to the front end properly. What is causing this difference?
  <doorOrWindow id='doorOrWindow-9f18f669-c8e0-420c-8f9d-047cfe20c9c5' level='level-2cb3862d-0a39-4c03-9343-1e9ad71c00f9' catalogId='eTeks#doorFrame' name='BasementDoor' creator='eTeks' model='12' icon='11' x='330.97003' y='-6.2835836' angle='1.7484555E-7' width='198.59497' depth='15.726523' height='211.29625' modelSize='1281' movable='false' dropOnTopElevation='-0.004801229' wallThickness='0.7874016' wallDistance='0.10498688' cutOutShape='M0,0 v1 h1 v-1 z' wallCutOutOnBothSides='true' boundToWall='false'/>
Re: Door height is different in XML when model is saved
I don’t know how you got 207.97 but my calculator displays 211.29752 for 83.188 x 2.54!
workingstorage
My calculator was set on EDT (Eastern Dummy Time)!
Thanks for responding :)
