In SweetHome3D.jar inside com\eteks\sweethome3d\model\LengthUnit_zh_CN.properties
Inside should be changed to
centimerUnit=\u5398\u7c73
The original has a few extra letters in front of it
This can lead to errors in area calculation units
Please fix as soon as possible
The full content of the correct LengthUnit_zh_CN.properties
# LengthUnit_zh_CN.properties 16 Mar. 2009
# Translated to Chinese (Simplified) by Zhao Si-cong
# Sweet Home 3D, Copyright (c) 2008 Emmanuel PUYBARET / eTeks <[email protected]>
# This program is free software; you can redistribute it and/or modify it under
# the terms of the GNU General Public License as published by the Free Software
# Foundation; either version 2 of the License, or (at your option) any later
# version.
# This program is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
# FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
# details.
# You should have received a copy of the GNU General Public License along with
# this program; if not, write to the Free Software Foundation, Inc., 59 Temple
# Place, Suite 330, Boston, MA 02111-1307 USA
# Units (\u00b2 is the symbol for supercript 2)
inchUnit=\u82f1\u5bf8
millimeterUnit=\u6beb\u7c73
meterUnit=\u7c73
squareMeterUnit=m\u00b2
squareFootUnit=\u5e73\u65b9\u82f1\u5c3a
Sweet Home 3D 6.5A bug was found in Sweet Home 3D
This topic has been viewed 10357 times and has 8 replies
Re: Sweet Home 3D 6.5A bug was found in Sweet Home 3D
I checked, even double checked with a binary editor and don’t see any hidden character in the [font=courier new]centimeterUnit[/font] line of LengthUnit_zh_CN.properties.
How do you see the bug that you encountered?
centimerUnit
centimeterUnit
These 2 words are not the same
centimeterUnit
It seems that the same mistake occurs in Russian
- dorin
@YGYL You've right. That is what I've discover earlier.
BUT
@Emmanuel Is something strange:
centimeterUnit must be the correct.
In this case CN & RU don't work as aspect but TW which have centimerUnit = work.
If change CN & RU to incorrect form = work.
I suspect it is also a misspelling in other place of translations.
How to verify and reproduce:
1. Open a home with rooms;
2. Set preferences to English & centimeter;
3. Menu->Tools->RoomsInfo ==> in table are m₂ => OK
4. Set preferences to Chinese or Russian and repeat step 3 ==> ft₂ => Not OK.
If change centimerUnit with centimerUnit in CN & RU files will work but it has no logic (at least for me).
BUT
I fixed this error in LengthUnit_zh_TW.properties, but it was the only wrong file.
In all cases, surface texts shouldn't be based on [font=courier new]centimerUnit[/font] property but on [font=courier new]squareMeterUnit[/font] or [font=courier new]squareFootUnit[/font] properties according to the current unit set in preferences, and to avoid wondering how to format surface texts, programs should use [font=courier new]getAreaFormatWithUnit[/font] in [font=courier new]LengthUnit[/font] class, like in the PlanComponent class.
Dorin, did you use the same way?
- dorin
@Emmanuel
I don't remember what I've use (it was long time ago) but probably I don't use this way.
At the moment I steel fight with roofs.
After I finish somehow this, I'll reanalyze RoomsInfo plugin and I'll tray to improve it.
Thanks for the clue!! I really need it.
I just checked the source code of the [font=courier new]TotalResult[/font] class you programmed, and you formatted surface texts another way in [font=courier new]UpdateCalc[/font] method.
As you compute the text of the surface unit [font=courier new]unitSurf[/font] from the name of the current length unit, this can lead to errors for languages where this name is localized (like Chinese or Russian).
A quick fix could consist of testing the current unit and not its name. Therefore, the line: should rather be:
Good luck for the roofs!
if (unitName.equalsIgnoreCase("mm") || unitName.equalsIgnoreCase("cm") || unitName.equalsIgnoreCase("m")) {Code: Select all
if (preferences.getLengthUnit() == LengthUnit.MILLIMETER || preferences.getLengthUnit() == LengthUnit.CENTIMETER || preferences.getLengthUnit() == LengthUnit.METER) {Emmanuel Puybaret, Sweet Home 3D creator
- dorin
Many thanks Emmanuel!!
Today I'll take a break from roof and I'll try to fix RoomsInfo.
If succeed I'll publish a fixed version.
Thanks again, without You, I have to spend mounts to find the bug (if I find)
