Installing plug-in
This topic has been viewed 7640 times and has 4 replies
luigisoft
Re: 90° Drehen vom ganzen Plan?
Post by luigisoft »
Hans,
Jumping forward 8 years, I am using Win 10. Into which folder in Win 10 should the plugins be installed. I am in the process of installing the plug in RotatePlan, but the folder described in the documentation is for Win 7/8 and this folder does not exist in Win 10.
Many thanks,
Trevor.
luigisoft
Post by luigisoft »
PS I am using Sweethome 3D, version 6.6.1., which I bought from the Microsoft Store.
Trevor
luigisoft
Post by luigisoft »
PPS,
continuing with this thread, I double-clicked on the file RotateHomePlugin.sh3p, which loaded the plugin into Sweethome. Version 6.6.1 states, that the RotatePlan plugin was successfully imported into Sweethome, but it does not appear in the drop-down list under Plan. This list goes down to the bottom of the screen. The last function on this list is Verkleinern. (I'm using the version in German). Rotate plan should appear below Verkleinern.
An ideas why Rotate plan is not appearing in the list?
When importing a plug-in, a window appears that says something like "plug-in will be available at next start-up"...
luigisoft
Post by luigisoft »
Thank you for your reply.
That message appeared after I had double-clicked on the plugin, but is not shown in the drop-down list for Plan after I restarted Sweethome.
Regarding the file path for Win 10, I found this C:\Users\Acer\eTeks\Sweet Home 3D\plugins.
Is this the correct path?
